40-201 Cabinet Stain Used
Just a heads up but all the mohawk toners on www.woodshopproducts.com are on sale and the shipping is a dollar or 2 cheaper. I just got mine ordered yesterday and paid a whopping $17 shipping where mohawk was $19.50 and cans are $7.79 but only paid $6.85 for each can there.
Kirk L
There are currently 5589 online users. [Complete List]
» 2 Member(s) | 5587 Guest(s)
