ron you son-of-a-gun!!
you just stole my 60 chassis on ebay!!! Icon_lol
i needed the dial scale to finish my radiobar,if you don't need it,let me know,phil
I saw TWO 60 chassis closing today on ebay.
hey exray,haven't seen you around lately,how's things in the middle of the ocean? i saw the other chassis but the dialscale is a mess,thanks for pointing it out,phil
Phil - PM sent.
