Philco 37-675 for $50
It appears that the prices for non-primo conditon radios has dropped quite a bit on ebay. I was the only bidder on a 37-675 that appears to be in good condtion but needs restoration. For $50 even the chassis is worth that much but to get a complete 675 for $50 is nice.
Wow, what a steal! I didn't even see that one.
I think I saw that one on eBay too. It was/is a De Luxe model, right? Congrats! 8)
Now why did this model originally cost so much more ($275) than the 37-116x ($195)? The 37-675x only has one central speaker, 12 tubes, and is not 'high fidelity' whereas the 37-116x had 4 speakers, 15 tubes, and IS high fidelity? I don't get it.
http://cgi.ebay.com/370059057990 Not in mint condition but it is complete and shouldn't be that hard to restore.
Claude, I almost bid on that. But the drive to get it, turned me off for right now. I was all set to hit that bid button, then I decided not to with about 30 seconds to go Icon_arrow Nice catch Icon_wink
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
I guess as with many of the 37 models you could get this one with the shadow meter or without and this one is without (magnetic tuning). It really appears to be a lot like my 38-1 with PP 6F6's with a 6F6 driver so the output should be 12-15 watts. It has 2 IF stages so it should have decent performance, I have someone that is willing to wrap it up and toss it on a greyhound bus so that covers the shipping issue. For the price with shipping I might have ~100-120 into this radio so that isn't too bad. Actually it is probably a better performer than the 38-1, when I went back I noticed the 38-1 doesn't have a 2nd IF and rather than using a 6J5 as an inverter feeding a 6F6 driver to the PP 6F6 outputs the 38-1 using a 6J5 inverter feeding two 6J5 drivers to the PP 6F6 outputs sucking up one extra tube for the same result.
PhilcoBenz, more than likely the $275 was a typo and it should have been $175. Normally there was about $15-25 difference between the standard and Deluxe model in 37 so I think the price was more like $175. The one nice thing is that the Deluxe model was the less produced model of the two types with the standard being over triple the total of the Deluxe.
You got a good deal on that set and you won't be disappointed in its performance. I restored a standard set a few years ago and was very impressed with it. I ended up selling it but it was tough to do. I have a 16X that I am going to keep and the two were a little too close electrically to justify keeping them both.
Sean
WØKPX
Well...taht's a start.morzh — 10:15 PM
X6 is out. Only pulling 3mA now, 220mA with the light on. Test point 18 is 12.2 Test point 19 is 12.06R3Sons — 09:46 PM
Philco 7053
Any of you guys have and used this tester?Martinj — 09:27 PM
I would test all, but the X6 is the main suspect. The output is the autotransformer, and it also could potentially ha...morzh — 09:13 PM
Yes, I tested them out of the circuits. I posted my measurements where the first letter was red and the second was blac...R3Sons — 08:52 PM
1. Have you tested out of circuit? 2. If yes, any transistor not showing E-C as OL is bad. From your measurements, all...morzh — 08:27 PM
42-345 Resistors
In short (I a sure you've seen the video Rich provided), safety caps are X and Y. X caps are placed across the Line/Neu...morzh — 08:21 PM
Restoring Philco 96
Today I decided to take on gutting the big bad cap block. I gave up on the same one from the 86 before, so I was not sur...morzh — 08:13 PM
42-345 Resistors
To not replace is to put it on the list to do later when they cook up! As a radio guy would say back in the day, lets sp...Paul Philco322 — 07:19 PM
Here's the readings from the AR14 (No markings on the one from the 5TPO) on the 6TPZ: B-E OL E-B .14 B-C 2.9 C-B .13...R3Sons — 04:17 PM
There are currently 1897 online users. [Complete List]
» 3 Member(s) | 1894 Guest(s)
