Philco 513 gallery picture
Ron,
Looking through the sites gallery, I noticed that you don't have an actual photo for the Labrador Gray 513, just an illustration. I was wondering if you like an actual picture of one. I would be happy to provide one of mine if you tell me what I need to do. Thanks!
Kevin
Kevin
Thank you, I absolutely would appreciate good photos of a real 513. Will send PM with directions. Thanks!
Philco 91 Tuning Condenser
There are currently 9952 online users. [Complete List]
» 1 Member(s) | 9951 Guest(s)
