Threads: 337
City: lawrenceville nj
hey guys
working on a 38-62 nos
http://www.nostalgiaair.org/PagesByMode ... 013211.pdf
I don't have a .006 can I use .068 or .1 ?
also a .25 can I safely drop to .22
thanks sam
Threads: 562
Your link does not work Sam.
Threads: 562
Sam
Have you noticed that the difference between 0.006 and 0.068 is an order of magnitude (11 times)?
And between 0.006 and 0.1 is 17 times?
You can't do that.
Now yes, you usually can safely replace .25 with .22. Provided they both are in the same units.
Threads: 337
hmm here link
http://www.nostalgiaair.org/PagesByModel...013211.pdf
ok so I don't have a .006 closes to temp try would be a .0047
for #23 6f6 tube
thanks sam
Threads: 145
City: Elko,MN.
How bout going up a little to a .01?
murf
Threads: 562
Sam
The closet standard value to 0.006 is 0.0056. I assume it is in microfarads so it is same as 5.6nF or 5,600pF depending on the search tool.
