Worth going to look at?
45L about an hour from me. Asking price is $100.
http://lasvegas.craigslist.org/atq/4283816801.html
John
Las Vegas, NV USA
Worth? Absolutely.
$100? If you really want it, otherwise personally I would haggle it down.
I would pay 40-50 for that. Its Vegas!, wanna gamble on it? Icon_mrgreen
Refinishing is a real pain with the legs. plan on using liquid stripper, a hard bristle brush and a tooth brush.
I've always liked that cabinet style:
http://www.tuberadioland.com/philco45L_main.html
I know radios are a bit more scarce in your area, but as others suggested I bet you could get that for between $50 & $75.
Agree not an easy cabinet to properly finish. BUT a VERY NICE looking cabinet when right.
The model 45 has BC and a nice fat shortwave band, similar to the 66, but it has one more tube than the 66. They are another example of a low tube count Philco that receives very well!!!
That's what I had thought I found near me a while back. It turned out to be a 66L instead and I just didn't feel like a 2 hour trip at the time. Now I would think the 45L to be more desirable. Hopefully you can haggle a little. Icon_smile
Nice radio.........Go Get It...
Philco 91 Tuning Condenser
There are currently 8480 online users. [Complete List]
» 3 Member(s) | 8477 Guest(s)
