Rust on Tuning Condensor - Suggestions for cleaning?
I have some pretty bad surface rust on my Model 87.
I have used Naval Jelly and had great results on the areas I could get to easily.
I have no idea how to get the rust off the tuning condensor and would love to have any tips there might be on cleaning it.
Should I just replace it?
You may be able to strip it, how much depends upon the construction.
I'd certainly have a go at taking out the rotor. Remove the end bearing and turn it to min capacitance and see if it will withdraw. Catch all the balls at the front. This may give you enough access for more rust treatment. Put the balls back in with grease before inserting the rotor.
It may be worth a try soaking the stripped frame in thin phosphoric acid and then cleaning. Dishwashers do work. However, the Paxolin insulators absorb water and need time to dry out... a week on top of a boiler does the trick. Resistance drops to a few K Ohms!!
I see you have an e-mail so I will send you an article that deals with one I did. Probably not quite the same but it may give you ideas.
If you can get an exact replacement then that maybe the best bet.
Gary
Gary
Thanks a lot for the help, I will give it a try. I had not idea how I was going to get in there to clean it up.
I appreciate any and all advice.
I’ve consulted a couple of the books which I got from Jim Koehler, Elements of Radio Servicing (Marcus and Levy, 1947) a...jrblasde — 10:58 PM
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
I think where the shaft comes out of the brass piece, there should be a clip.morzh — 06:47 PM
Well, you're right but the AVC gets to the control grid through the IF secondary, no direct connection to the control gr...RodB — 06:36 PM
Where do I look? 7B7 Suppressor? Both these radios seem to connect the SG to AVC. Which I am not sure why, but then ...morzh — 06:27 PM
