Phillips Knobs
I need three knobs like this Icon_smile . They are from a Phillips Jupiter 543. Does anyone have these. Icon_think or know where I can get them. Joe
[Image: http://i927.photobucket.com/albums/ad118...81a12e.jpg]
Joe have you tried these folks? http://www.philcoradio.com/resourceb.htm#l
I am sent a message to Julie.
Thanks Icon_smile
Joe
Those look like bandswitch pushbuttons/keys? I think that you may have to either mold your own or look for a source in Europe. There was some site I saw from over there that made reproduction parts for Phillips radios, though they may have been for older models.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7232 online users. [Complete List]
» 1 Member(s) | 7231 Guest(s)
