Philco 51 bypass can
Does anyone know how the five caps inside the metal can, item #23 correspond to the caps in the schematic?
The can had a .1,.15, .25, .5, .5 uF inside, but they are gone.
How do they match up to 2 det. screen bypass, 2 det. cathode bypass,
2 det. plate decoupling bypass, output tube grid bias bypass, 1 det. & I.F. screen bypass ?
I have checked Riders, Beitmans, RCC, and original Philco service literature, but no luck.
Thanks
John
http://philcoradio.com/tech/images/50.jpg
This shows wire color and cap values. It close to a 51 so maybe it will help?
Thanks tab10672
That's what I needed
John
Philco 91 Tuning Condenser
