  • 1 Vote(s) - 5 Average
Philco 45 Butterfly Restoration Chronicles....Finished
#46
Here is a picture that is not the best lighting, I will take it outside later today for some better pictures. I have put it next to other radios that have that very dark look but you just know that its not black and this one still looks black. There are none of the tell tale signs of refinishing that makes me believe it is the original finish. I have not seen another so have nothing to compare to.
Gregb
I have an 18b with the same "style" finish that is original and although pictures you see make them look black this one is a really really dark brown. Actually the only way to see its brown is to hold something black against it in good light.
#48
Kirk, you brought those radios back from the dead before, and you'll do it again with even better results this time. Sometimes, after something like this happens, you just need to walk away and take a break for a while.
Philco 91 Restore Code ??
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 2397 online users. [Complete List]
» 3 Member(s) | 2394 Guest(s)
