Sparton 811,,photos
I bought this Sparton from the original owner and he used to listen to it years ago but he said 'it just quit''. I recapped it and replaced a burnt out resistor and now it plays very good.
I stripped the cabinet and applied grain filler and one coat of stain. when it gets warmer I will finish the cabinet.
I bought it because I really liked the inlayed wood.
Nice and looks nicer after what you have done.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6707 online users. [Complete List]
» 1 Member(s) | 6706 Guest(s)
