Tale of a Z
#31
Brenda,
Thanks so much for showing us how you cleaned up this chassis. I'm very impressed with your persistence and not giving up. You did a really nice job.
Tom
#32
WOW, Brenda!!! VERY nice work!
Icon_thumbupIcon_thumbupIcon_clapIcon_wave
#33
And the final pic, including the beautiful repro knobs from RenovatedRadios:
#34
Brenda,
The icing on the cake.Icon_smile Nice!
Tom
#35
I never saw a Z with a knob in the middle of a black dial.
Great job, Brenda, but to be honest this particular Z is not my type.....a knob in the middle of a black dial, well, breaks the scenery so to speak. I don't get that look.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7138 online users. [Complete List]
» 1 Member(s) | 7137 Guest(s)
