Philco 16B CL find
I picked this up today. It is intact and hopefully no surprises. Now I have this version, a shoulldered version and a 116B. When this one is cleaned up, they will all get lined up together in my home office display.
Nice find, what did you cough up for it if not a secret?
Sent you a pm.
Looks good! Icon_thumbup
VERY nice find!! Icon_thumbupIcon_thumbup
Thanks. I am happy that the chassis is original also except for two e-caps.
The walnut is in nice shape too, just the toner is flaking all over. I need to find out what color to use there. All in all an easy (it appears) restoration.
Steve,
I too would like to know the purchase price since I have one. I used Mohawk's Van Dyke toner for the dark areas when I refinished mine.
I paid 50 for it. I never pay more than that unless it is a very rare radio.
Steve nice grab. I bet it will come out beautiful when your done with it.
Thank you. I love my Philcos. They are great playing sets. This one is in really good shape considering. No significant repairs and the cabinet should be an easy restore.
Philco 91 Tuning Condenser
