Philco 50 (early) survivor
Threads: 92
City: Clayton, NC
Found yesterday in Winston Salem, NC.
Cabinet good shape, needs grillecloth.
Chassis virtually no rust, still has both copper mershons and ALL Philco globe tubes!!
Besides a good cleaning and grillecloth replacement, I am not sure if I want to do anything else to this survivor!!
Threads: 55
City: Evanston, IL
Threads: 92
City: Clayton, NC
Thanks, Guys! Oh yes, and it cost 100.00 !!!
Threads: 562
Well worth it Tom, and the cabinet looks good.
Chassis cleans up easy if no rust present, so I do not even consider it a chore.
Threads: 271
City: Wilsonville
State, Province, Country: OR
Threads: 562
I know what I will do.
I will restore another 70, patch the middle hole, put the On/Of trigger switch in the back and declare it a 50.
Threads: 55
City: Lexington, KY
Threads: 11
City: Black Mountain, NC
What year by chance?
Cossor 3468
GE 417A
Philco 118H
Radiola 17/100
Scott 800B6
Silvertone 6130
Stromberg 535M
Truetone D1952
Threads: 562
Should be 1931.
They used 70 cabinet and drilled the front panel for 50 shaft pattern.
Threads: 367
City: Dover, OH
Ah, very nice! I have a model 50 in the later cabinet style. Paid about the same for it.
Threads: 562
50 is the one with the transformer underneath the chassis, right? Or which one was it?
That was a dumb idea though.....
Threads: 43
City: Atlantic Highlands, NJ
Great condition! Good luck with it.
Threads: 92
City: Clayton, NC
Yes, power xfrmr is under the chassis.
Threads: 562
Dumb. That's just dumb. Like the transformer runs so cool that being in enclosed tight space will benefit it greatly and at the same time the rest of the under-chassis denizens.
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
There are currently 10208 online users. [Complete List] » 1 Member(s) | 10207 Guest(s)
