Unknowm Philco Model. Please Help
Hi All:
I selling a Philco Tropic receiver, but I unknowm wich model is it. It have 4 SW games and MW (broadcast)- No FM- It is make in Argentina
Anyone Known this model?
The receiver can be see in :
http://articulo.mercadolibre.com.ar/MLA-18720196--_JM
Thnaks in advance
Heriberto
There are currently 9538 online users. [Complete List]
» 2 Member(s) | 9536 Guest(s)
