  • 1 Vote(s) - 1 Average
Not receiving all stations on AM
#31
Thank You Victor and Joe... You have given me things to look at and think about for this problem. I seem to be able to do an alignment on AM but for some reason I do not pick up many stations. If I use another am radio I am able to hear stations all through the band but on this I seem to not get any stations towards the lower and higher end of the band. Joe I tried t hook up a wire to all the ground lugs I could find and ground them with the wire but that didn't seem to make any difference in any hum. I do get a couple stations very well but any others that I do pick up isn't very clear, seems it should be more sensitive and pull in more stations than it does. I will keep trying your suggestions.
#32
I found something strange. I found that when listening to AM and I use a wooden stick and brush it across the variable tuning capacitor plates I can either lose a station or it can bring more stations in. Do you think it is a bad ground, or the tuner needs cleaned better or maybe the plates aren't aligned right? They all look straight. Hoping someone can lead me in the right direction to fix this. Considering it can make the tuner pull in more stations , or lose the station, I am thinking this is my problem with not receiving a lot of AM stations. Any ideas?
#33
warren.....antenna connection is very important on this radio for local and long distance reception. I think that I mentioned if the chassis is in the cabinet then hook up the loop am antenna leads connecting the white wire to terminal 1 and the black wire (ground) to terminal 2 then try your stations....then switch black wire to terminal 3 and try that.....if the chassis is out of the cabinet then try making a large loop antenna out of aligator clips and connect as described above. Also have you cleaned out the tuning capacitor fins with contact cleaner.
#34
I have been useing the original antenna for the radio when playing and testing. I am going to clean the tuner again. I noticed if I tap on the top of the chassis above the tuner cap that it loses the station but I am starting to think that maybe when I do these things the tuner is just moving a very small bit and thats why I lose the station. I am doing more testing... Icon_e_wink
Philco 91 Restore Code ??
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
There are currently 2510 online users. [Complete List]
» 3 Member(s) | 2507 Guest(s)
