Hey Mike
Ever seem one of these???
http://www.radiomuseum.org/r/lenin_kozi_...eceiv.html
Looks like it would be fun to play with, but I'm weird! The timing of it's production and the layout is very similar to the US National Co's SW-3.
https://home.comcast.net/~wa9wfa/ha00004.htm
Wouldn't mind finding one sometime.
No I never saw any of these.
I had an Army mobil radio station (ratziya in russian), but never really fired it up.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
