useing Correct color for Radio
Threads: 26
City: Hayward, California
Here is a pic of my 47-1230 I have been refinishing. I think I have the lighter color correct on the Radio but I'm not sure on he darker color that goes on the trim, etc. On the picture I have below the Radio a piece of wood with a Dark American Walnut stain on it but it doesn't look quite right to me. I am hoping to get some of the Expert opinions here on the forum about the color is right before I spray it on the Radio and whether the Radio looks good so far to you. Thanks for any input. Warren
[Image: http://i1348.photobucket.com/albums/p721...2b39af.jpg]
(This post was last modified: 03-09-2014, 06:00 PM by Warren.)
Threads: 310
City: Kings Park NY
it looks beautiful, how did you get that gloss finish?
AC: 4 DC: 1
Threads: 562
You guys keep wowing me today, so again - WOW!
This is gorgoeus.
Here I am trying to figure out what to do about the measly base trim on my 70 and there you are having created a marvel.
No, I need to take a class.
Threads: 26
Thanks Guys. I used a gloss clear laquer and mixed the toner with it. I sprayed it with a spray gun and compressor. I still l need to put a few coats of clear on it but first I need to put a dark toner on the bottom and the face plate, etc. I sprayed that piece of wood underneath it with the dark I have but it doesn't seem like it is quite the right color for it. Am hoping someone can tell me for sure.
Threads: 242
City: West Bend, Wisconsin
That looks AMAZING, Warren!! Well done. What color toners did you use? My set with the original finish is a bit darker, but I certainly wouldn't change yours just because of that. Yours shows off the beautiful grain in the wood much better.
Threads: 26
Thanks Greg, I used a medium walnut toner from Behlin. I figure that the original finish probably darkened with age so I didn't make it any darker. Do you think the color of that board underneath the radio would be the right color for the darker parts on the radio?
Threads: 242
Do you mean the ribbed board that runs around the bottom front and sides? It might be a tad light but it looks fine. You could make the speaker / phono door a similar shade for contrast.
Threads: 26
yea, the bottom strip. the speaker/phono door, the front plate where the radio goes and the 2 strips on the top, above the light area are supposed to be a dark tone. I just want to make sure the color I'm planning on using ( that is on the wood below the radio) is close to original.
(This post was last modified: 03-09-2014, 11:57 PM by Warren.)
Threads: 562
I just looked at it today again as I was opening the thread, that looks yammie. No, really, if I ever be able to do something like it, I will then sit down near it and won't quit sittin' until the next day or so. Or until the beer runs out.
City: Kentucky
You can do it Mike! .... Just jump in and start. It isn't hard to do.
Threads: 562
Not before we buy that new place where I'd have a room, or come summer, maybe outside. I have 1-place garage and there is no way I am doing this inside the house.
Threads: 26
So far no one seems to have a problem with me using that dark color on the board below the radio for the dark parts on the radio. Hopefully it is close to original color. I will plan on using that dark american walnut for the rest. If anyone thinks its wrong please let me know. thx Warren
(This post was last modified: 03-10-2014, 06:02 PM by Warren.)
Threads: 26
OK, I have put the second color on my Radio. Here are a couple pictures I thought you might be interested in.. Next step is to put a few coats of clear on then rub it out.
[Image: http://i1348.photobucket.com/albums/p721...df8717.jpg]
[Image: http://i1348.photobucket.com/albums/p721...ba77e9.jpg]
Threads: 271
City: Wilsonville
State, Province, Country: OR
Threads: 562
Warren,
It looks great. Again, I am not a specialist and have no experience in judging Philco colors.
Just curious if not too much cherry in it? I thought Philcos of this type have a hue a little less purple and more reddish yellow (you see, I do not even know how to call those colors). I am sure Ron/Arran and a couple of other guys here know exactly wherther this is it or not.
But this said, the workmanship is amazing and it looks great.
Philco 91 Tuning Condenser
I thought you meant the actual dial....there are rivets.morzh — 08:42 PM |
This is what I meant.morzh — 08:37 PM |
Here are the links. 6TPZ and 5TPO
The speakers are good. I've tried several known good ones. I just have to fi...R3Sons — 06:27 PM |
I just found a set screw. Was able to turn dial just enough to see it and loosen it. I have it off now.dconant — 06:14 PM |
Hello,
Does anyone know how the dial plate comes off the tuning condenser shaft? The dial itself id so warped I can't...dconant — 06:01 PM |
Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit...morzh — 04:29 PM |
Transistors are easy.
Or touch your fin...morzh — 04:25 PM |
Hi Mike, I believe I tried different ways to change the header for my post but no luck. Anyway thanks for changing it fo...462ron — 04:02 PM |
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
