philco 41-230 parts list
Hi Guy's,
Have a Philco 41-230 I want to re-cap, but Nostalgia has no parts list for this chassis.
They have schematics, but I cannot read the values on their schematics.
I want to do the electrolitics first, and it looks like someone has been in there before and put in a double cap with I believe is a double 8 mfd 450 volt cap.
Can't be sure if that is what should be there as I cannot read the blurred schematics from NA.
There is also a large cap which was replaced which is number 40 on the schemtics.
Numbers are not legible on the cap, so I have to rely on the parts list, which I do not have access to.
Any help from anyone would be appreciated.
Thanks
murf
[Image: http://i1161.photobucket.com/albums/q509...1-2301.jpg]
Hi Murf:
I have a nice clear schematic with values if you still need.
Gregb
Input cap is 12mfd output is 4mfd@450v
murf, there's a parts list in the service bulletin you can find here: http://www.audiophool.com/Philco.html
Thanks Bob,
Unfortunately I can't view it with the windows software that I have.
Don't want to purchase what they want to sell you to be able to view the djvue(whatever) format they use.
murf[/font]
[font=Tahoma]
Here ya go, a pdf version of it.
There are currently 10826 online users. [Complete List]
» 2 Member(s) | 10824 Guest(s)
