  • 1 Vote(s) - 1 Average
49-905 Mica Disease-FOUND IT!
Don't worry Don, that kind of stuff never gets thrown out! What size mica cap do I use?
Eric
The Villages, FL
Most of the time 100mmfd will do the trick.
That's one of the problems with repairing those mini IF cans, the values are not marked on the schematic, or rarely are, and not all IF cans used the same value capacitors, sometimes not even the same set. On some you can use 100 mmf/pf, on other you need 120s, others something else.
Thanks guys. It looks like a good project.
Eric
The Villages, FL
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
There are currently 2829 online users. [Complete List]
» 2 Member(s) | 2827 Guest(s)
