Threads: 113
City: The Villages
Hi guys,
I just did a recap on this Hippo. I even replaced most of the mica caps as well as a good amount of out of range resistors. The tubes have been tested and I replaced 2 of them. Performed an alignment.
Reception is great but between stations there is a VERY noticeable squeal. Any ideas where to look?
http://www.nostalgiaair.org/Resources/634/M0013634.htm
Thanks
Eric
The Villages, FL
Threads: 145
City: Elko,MN.
I have run into this before, and have been able to get rid of it by fine tuning the alignment.
murf
Is your loop antenna properly connected? If one wire is disconnected, the set will squeal, howl, buzz, and in general not play correctly.
Threads: 55
City: Evanston, IL
If your loop is connected you may also try a slight stagger-tune of the I.F.'s as suggested above.
Chuck
Threads: 113
City: The Villages
It came with no antenna. The loop is connected but it is from what I think was a 46-250. Would that make the difference? If so what can be done to correct this?
Eric
The Villages, FL
Threads: 563
If it squeals on you tell it it is not an honorable thing to do.
And make sure it is loop and not a noose
Now on teh seriuous note, I only have the sch for 48-620, but if it is also an AC/DC set, there is a capacitor or a capacitor in series with small inductance conencting the electrical common and RF common (chassis). If this cap or inductor are bad the radio will misbehave including squealing, howling, roaring, motorboating and occasionally uttering some bad words on its own at which point you should turn it off, pull the belt from your pants, give it a good threshing and then inspect for bad parts and re-align.
Threads: 113
City: The Villages
OK Morzh, here is the schematic for the 48-460
48-460
Would it be C5?
Eric
The Villages, FL
Threads: 113
City: The Villages
Something else that I just discovered: With the antenna disconnected I get a soft high pitched squeal that changes with volume but doesn't change with movement of the tuning cap.
Eric
The Villages, FL
Threads: 563
No. C19.
But C5 is also worth checking as without it the antenna will simply not work.
Threads: 113
City: The Villages
C5 is new. Any idea why there is a soft squeal with no antenna connected?
Eric
The Villages, FL
Threads: 563
Is C19 new or is it even there?
Threads: 113
City: The Villages
Yes it is there. I have 2 schematics. This one shows a .2mf and the other shows a .5mf. I used a .5 because that is what was in there. It didn't have the wire wrapped around it. I don't think that is needed anymore. Is it?
Eric
The Villages, FL
Threads: 563
Did it have a wire wrapped around it before?
0.2uF or 0.5uF does not matter, it is an RF link cap between the two commons, either will work fine.
Threads: 113
City: The Villages
No wire, so I tried one. No change.
Eric
The Villages, FL
City: Kentucky
Hippos usually have rubber wiring. Did you replace any wires, or cover them with heat shrink? If so, check the routing of the wires. Sometimes solving a squeal is as simple as moving a wire 1/4 inch. If this isn't the trouble, i think your alignment might be a little too "hot". Like Chuck said, un-align it a little and see if the squeal stops.
Model 27-84 BUZZ?Humm?
Hello Bruce,
First all do mean a 37-84b ?
Did you take any before and after pictures ?
is it a buzz like when you touch...radiorich — 01:59 AM |
Hello Tim,
Yes, I even check all of my replacement parts when I install them and I too had a capacitor go bad not long a...radiorich — 01:54 AM |
I got back into it tonight. Problem found and resolved! Sometimes it helps to take a break and think things over. It was...TV MAN — 12:40 AM |
Thank you. I have to take a break from it for about a week. I'll have to do some thinking. I was toying with the idea ...R3Sons — 12:21 AM |
Drowning in a overloud buzz/Humm. Have already changed filter caps,bakelite blocks( caps),out of speck resistors,checked...Bruce — 12:17 AM |
Philco 630csx power cord
Hello Mike
Here is the Link to the company the place is called Grand Brass lamp parts .
I buy all my Lamp parts plus ...radiorich — 12:00 AM |
Is the tube in your radio actually 35Z3 or 35Y4, or something else?morzh — 10:55 PM |
Second Rich's opinion.
Run a separate antenna wire. Use a separate plug.
Rich
Where did you get this wire? Se...morzh — 10:51 PM |
On K2, pins 1&2 are shorted. On K4, Pins 1&3 are shorted. Others are OK. - your 0.047 caps are fried in both
Th...morzh — 10:40 PM |
Hello Tynwald ,
I would not use that plug and what I would do is us Some of this cloth covered wire !
you can also buy...radiorich — 10:28 PM |
There are currently 2664 online users. [Complete List] » 1 Member(s) | 2663 Guest(s)
