RCA HF4
Picked this up Friday. See http://philcoradio.com/phorum/showthread.php?tid=9076
Posting before and after GoJo photos. There will be more cosmetic and electrical restoration over this summer. I had to clean it up enough to keep it in with the general population in the house..
Well, the difference is clearly visible and I think the finish is good enough to be kept.
Nice animal.
The gojo did a better job then I would have thought . I think it looks good. Nice find.
Henry
GoJo is a good way to clean your decent original finish. After it dries, you rub down the cabinet with a clean cloth and then apply a polish of your choice.
That is a nice find, Tim! Icon_thumbup
Make sure to update us on the performance of your set!
There are currently 6448 online users. [Complete List]
» 2 Member(s) | 6446 Guest(s)
