I guess it pays to be lucky !!
My 118B is just about restored electronically !!
But I needed new cloth for it ! YEAH good luck finding anything close !
But look at what I won on Ebay Tonight !!
Perfect match !! can't wait to try it on !!!
Rock
Kenny?
Very lucky indeed!
Always nice to hear good news!
We are anxiously awaiting pics of your nice 118 with it's new grillecloth, John!
That is a nice set!!! Color me envious! Icon_thumbupIcon_thumbupIcon_clapIcon_wave
Philco 91 Tuning Condenser
There are currently 5432 online users. [Complete List]
» 3 Member(s) | 5429 Guest(s)
