Philco 86 lowboy, what speaker?
I just ended up with a decent Philco 86 Lowboy cabinet today. Only thing missing is the back and (of course) the speaker grill insert. I might have already located a chassis, but what type speaker did this use and what other Philco speakers might work?
http://philcoradio.com/phorum/showthread.php?tid=215
Link should go to speaker list
Tim
Thanks! That should help. Icon_smile
There are currently 2318 online users. [Complete List]
» 2 Member(s) | 2316 Guest(s)
