Testing Philco 41-300 tubes
I recently picked up a 41-300 which I want to restore. It looks real nice just looking at it and only thing that appears to be missing is power cord which I will replace. I am fairly new at posting on internet forums so if I am posting this question in wrong place forgive me.
My tube tester will not test half of the tubes on this radio , they are the "S" shape and "ST" shape tubes. I am looking for someone in the Southern Illinois area (Marion) who can help me test these tubes?
Thanks for any help out there.
Bob H.
Hi Bob
Welcome.
If you're willing to travel to Evansville, Indiana, I'll test your tubes for you...E-mail or PM me for details...
Hi Bob,
Check your private message. I live in Marion and can offer some assistance.
There are currently 10431 online users. [Complete List]
» 2 Member(s) | 10429 Guest(s)
