Model 90 alignment procedures
Afternoon,
Being I am an avid 20's guy I do not get to do too many alignments I am kinda lost at the moment.
I presently have a Model 90--single 47 output on my bench. It performs quite well with one slight problem of a shadowed local station--71 KEEL. I receive it quite well and then if you move the dial slghtly to the right I can pick it up again --not nearlyas loud. The upper band seems fine.
Is there a site that can describe the alignment procedures?? I do realise the IF is 175kc. I need a tutorial to ensure I am doing things correctly.
Thanks guys!
Dave
Align the IFs first. I can't remember, but I believe one of the 90 series versions lacks AVC. I recently used a scope. See my thread here
http://www.philcoradio.com/phorum/showth...p?tid=1258
Not saying this true on all sets. But, it sure made me a believer on the accuracy of the IF alignment. If it lacks AVC, you can use the plate of the output tube. It's explained pretty well in the thread. You can even use a VOM for this.
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
Dave and Brian, the model 90s with a single 47 output or two 47s in PP both have AVC. Only the early models with the two 45s in PP do not.
M R Radios   C M Tubes
Thanks for that info. I wasn't sure which version.
-Brian
Thanks guys for your help. I got it all aligned and playing well.
Dave
Icon_wink
-Brian
New member
Philco 630csx power cord
New member
There are currently 4039 online users. [Complete List]
» 1 Member(s) | 4038 Guest(s)
