Radiola 25
Craigslist find. 45 bucks. No tubes.
[Image: http://i1319.photobucket.com/albums/t679...719b3a.jpg]
[Image: http://i1319.photobucket.com/albums/t679...3901d3.jpg]
[Image: http://i1319.photobucket.com/albums/t679...7b5ba2.jpg]
Voltmeter was inside.
Antenna center post seems to be broken/rotted where it meets the base underneath.
Some of the stuff I found inside the Radiola.
Extra battery hook-up card. Extra metal I.D. plate.
[Image: http://i1319.photobucket.com/albums/t679...0f7fe6.jpg]
Inspection tags, wooden ring for the antenna mount hole.
[Image: http://i1319.photobucket.com/albums/t679...ec687a.jpg]
Battery...or ?????
[Image: http://i1319.photobucket.com/albums/t679...a76881.jpg]
It's a project. But the price is not bad.
Icon_thumbup Very nice!!
isn't that black rectangular ditty there a capacitor?
I saw a photo somewhere on the vast inter web of someone holding one that still had a tag. It's a condenser. No idea what value it's supposed to be yet. This is a big part of the fun to me, solving these mysteries.
There are currently 3464 online users. [Complete List]
» 1 Member(s) | 3463 Guest(s)
