Voltages-socket pins for Mystery Control
#46
Bill- I might be interested in a pack soon- I have a "Mystery Control" 39-116, and just picked up the remote on e-bay... The 39-116 is a couple notches down the line fomr the 37-650 I am currently overhauling, and it needs a full go of it: must have been a barn find, judging from the mouse droppings and crud on the top of the chassis! And of course decayed rubber wires!
So, once the 39-116 project is under way, a battery for the remote would be quite useful. Drop me a contact info e-mail so I can keep it on file.
Thanks!
Scott
Old Cars, Old Radios, Old Pipes and Young Women... What more is there?
#47
batterymaker at gmail dot com is the address.
#48
My first finished Mystery Pack should be on eBay sometime today.
