New Philco
Sweet! That is so nice! GREAT find!
Thanks for all the compliments! It is a really nice condition set and I am very happy to have both pieces. I think this one will reside in the living room when completed, it is worthy!
Gregb
Well, not that I want to add an other congratulating message to this thread, but....
CONGRATS! Icon_biggrin This set is awesome. You rarely see radios that were preserved so well.
Yup, this one deserves being in the living room.
There are currently 5423 online users. [Complete List]
» 4 Member(s) | 5419 Guest(s)
AvatarAvatarAvatarAvatar
