Philco 3537 interstage transformer
I used my LCR meter to look at the 3537 transformer used in Philco 111. The Table on Chuck's website does not list inductances.
The primary inductance is about 25H, +/- 2H at 1000Hz.
The one half secondary is 93H to 100H, which makes the full one about 180 to 200H.
The leakage inductance is 165mH.
This makes the primary and leakage data closest to Hammond 124B.
Of course there is the discrepancy of 1:4 for Philco and 1:3 for Hammond's turns ratios.
Outside of a rewind or custom wound transformer theres not much available I use a 124e in my sparton 1466 which the push pull driver to push pull output was all so 4-1 with a 124e which was 3-1 I have had this radio since the mid 1964 and the original failed about 2 years ago so I know what it sounded like before it failed could not tell any difference this radio has variable if bandwidth 20 watts output and 12" woofer two 5" tweeters. I think it should be fine to use a 124b in yours I put it in the old housing so it still looks original,
I just installed 124, sorry forgot the letter, driver for a guy in his Airline radio with a #27 driving PP 45's and it sounds great with tons of volume.
Gregb
I am considering buying an 124A or B (E is not necessary and in fact B is closer to the Philco one in primary inductance so the response would be the same more or less).
The difference between A and B is almost 20 bucks. I am somehow sure there will not be huge difference in quality - this is after all not a HiFi output.
But first I want to get replies with quotes from Heyboyer and MTT (the latter is in NJ close to me). Just wonder what they suggest money-wise, they would have to unwind and replicate.
42-345 Resistors
Pholks: What are these little cylindrical objects inside Little Phil? They seem hollow. I don't think they are capacito...proftrussell — 12:39 AM
[split] New member...
Well, the paint thinner didn't get the job done but some heat did.  I got it apart, got everything cleaned up, re-lubed,...HowardWoodard — 12:24 AM
The gear on the 37-604 is exact same, but there was no pin. The pin exists on the gear of 37-116 or those ones with rob...morzh — 04:31 PM
I agree, the two should not be connected. Due to poor image quality of the original Philco schematic, it was unclear if ...jrblasde — 02:25 PM
New 37-116 Parts
Dan, I'm curious, I saw the 38-2 dial you got from them. Are you getting a new, improved one from them without the wh...Greg — 01:59 PM
New 37-116 Parts
They are not closed. I sent an email to them 3/8/2025 and got a reply back 3/10/2025. Since 3/8/2025 was a Saturday I di...dconant — 01:22 PM
Gloritone 27 Radio
Hello, The radio is playing now using the repaired antenna coil. MrFixr55 you stated a while back I might need to add...dconant — 01:10 PM
New 37-116 Parts
Well, their answering machine says they check their messages every day at noon and respond by 3p the next day - I can sa...Doppleganger — 01:09 PM
Thanks 462ron. I have it soaking right now but will test the power of my shop light magnet on the pin when it comes out.HowardWoodard — 11:39 AM
Wasn't that the Suppressor grid that we were talking about, that got connected with the AVC? Anywho, the initial questi...morzh — 10:53 AM
There are currently 3259 online users. [Complete List]
» 1 Member(s) | 3258 Guest(s)
