48-1256 radio / phono
I replaced the cartridge in the photo and the sound is clear but I can't get the (volume) sound high enough. The radio volume control works ok.Is there some way to increase volume other than turning knob?
If the shielded cable is not grounded would that make a difference ?
have someone move this to electrical forum and they will be able to help. I am useless with this topic. Icon_silent
Thanks
Lumberman, if the radio volume is fine (loud enough) and the phono is weak, it suggests that perhaps your replacement cartridge is either weak or perhaps of the wrong type. Cartridges have a wide range of output voltages depending upon construction. Selecting the proper voltage output is fairly important.
Can you advise what cartridge you installed?
Refer to the schematic as to where the shield should be tied. That may or may not be a problem. It appears the shield is grounded to the changer base.
http://www.nostalgiaair.org/PagesByModel...013612.pdf
Jerry
There are several types of cartridges some have much higher output than others. I would suspect that you have a cartridge that has a low output or is a low impedance output. What cartridge are you using??
Jerry and Terry, thank you for your replies. The cartridge I installed is a Astatic 32 it states on the box that it replaces Astatic 34;l-24-a;l-36-a;l-82-v;l-92-a. If this is the wrong type where do you suggest I look for the right one,can you test the cartridge for voltage out put. The cartridge I replaced is a Shure crystal pickup cartridge P907, below that it states 35-2643. Tim
According to the schematic the shield is grounded to the turntable chassis and not at the radio end.
Jerry
I agree, the two should not be connected. Due to poor image quality of the original Philco schematic, it was unclear if ...jrblasde — 02:25 PM
New 37-116 Parts
Dan, I'm curious, I saw the 38-2 dial you got from them. Are you getting a new, improved one from them without the wh...Greg — 01:59 PM
New 37-116 Parts
They are not closed. I sent an email to them 3/8/2025 and got a reply back 3/10/2025. Since 3/8/2025 was a Saturday I di...dconant — 01:22 PM
Gloritone 27 Radio
Hello, The radio is playing now using the repaired antenna coil. MrFixr55 you stated a while back I might need to add...dconant — 01:10 PM
New 37-116 Parts
Well, their answering machine says they check their messages every day at noon and respond by 3p the next day - I can sa...Doppleganger — 01:09 PM
[split] New member...
Thanks 462ron. I have it soaking right now but will test the power of my shop light magnet on the pin when it comes out.HowardWoodard — 11:39 AM
Wasn't that the Suppressor grid that we were talking about, that got connected with the AVC? Anywho, the initial questi...morzh — 10:53 AM
Hi Howard, if memory serves, and many times it doesn’t, I vaguely remember working on a Philco that had that pin you hav...462ron — 09:00 AM
Gloritone 27 Radio
Hello John, Thanks for the information and Arran I have heard of Wells Gardner and I have heard of Apex but I did not ...radiorich — 08:17 AM
Gloritone 27 Radio
Another make I have seen from U.S Radio and Television was Apex Electric, or U.S Apex, the badge on some of those had a ...Arran — 12:56 AM
There are currently 2867 online users. [Complete List]
» 3 Member(s) | 2864 Guest(s)
