46-1209 turntable I.D.
Need to find a needle/ cartridge for this unit, & can't find a model/ type
number for the changer. Only numbers are beneath the deck stamped with an ink stamp. 6832 are the numbers. Anyone been successful
finding parts for this old of a unit?
Could be it takes a steel needle?? Can't really get it out until I get the chassis recapped & moved.
Thanks for any help.
Jim
Either a D10 or D10A probably. They have different cartridges. A picture would help Identify it. Parts are hard to find.
Thanks, Warren. Cabinet is currently at the back of the bench with chassis ahead of it. Will try to post pics soon for I.D.
Jim
Philco 91 Tuning Condenser
There are currently 3941 online users. [Complete List]
» 2 Member(s) | 3939 Guest(s)
