I need a radio ID!
Just sent and inquiry about this radio I found on Craigslist. Looks like a Philco to me, but I no idea which one. Anyone want to take a guess?
[Image: http://images.craigslist.org/00R0R_3UQGP...00x450.jpg]
Does Not look like a philco to me but looks there is no radio inside of it.
ask what it says on the escutcheon
Definitely not a Philco. It is a Crosley New Fiver.
Moved to Other Radios (Non-Philco) since it is not a Philco radio.
Ah! Thanks!
There is a radio inside of it, just not in the this photo. Haven't heard back from the seller, so it could be a moot point anyway.
Crosley 167.
There are currently 4926 online users. [Complete List]
» 1 Member(s) | 4925 Guest(s)
