Magnavox CR-192 FM Tuner Dial Scale
I recently picked up a Magnavox CR-192 FM tuner. Unfortunately the dial scale is broken. I have not been able to come up with a reproduction or a replacement. Has anyone had success creating their own dial scales using a clear transparency sheet?
I've done that several times, but I need a significant (most) part of the original dial to make it happen, or a good quality scan of one.
Thank you for the feedback. I will keep that in mind.
It looks like I have found a replacement dial scale.
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 4271 online users. [Complete List]
» 1 Member(s) | 4270 Guest(s)
