  • 1 Vote(s) - 4 Average
Removing Philco 20 Dial
Are there instructions on this site on how to remove a Philco 20 dial and replace it? Thanks
nuke
I have no chassis out, but unlike even in 70 o 90, 20 as I remember it, disassembles so intuitively I never had to look anywhere for directions.
And this was my very first radio.
Just look at it - it is almost self-explanatory.
There are currently 10160 online users. [Complete List]
» 1 Member(s) | 10159 Guest(s)
