What Is A Hazeltine Standard Test Loop #1150
My 46-480 alignment procedure calls for a Hazeltine Standard Test Loop #1150 to be used at certain segments of the alignment. What is this test loop and where can I obtain some info on it? Can I build one? Thanks much Icon_exclaim
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
