Fisher Studio Standard gear on Craigslist
Figured Ron or someone else here might be interested in this:
http://raleigh.craigslist.org/ele/4474048866.html
It's probably all right quality wise, but it's equipment made after Sanyo bought the Fisher name so it doesn't really have any collectable value like the older U.S made Fisher stuff does.
Arran is right, neat stuff but too new for me. Plus, as Arran said, it's Sanyo Fisher so it is generally not up to the quality standards of the original Fisher Radio Corporation.
There are currently 10633 online users. [Complete List]
» 2 Member(s) | 10631 Guest(s)
