Philco 59c Cabinet Restoration
Here's a summary of the restoration done on a 59c cabinet.
As received:
[Image: https://www.dropbox.com/s/7wwjji0sb2p19n....jpg?raw=1]
and
[Image: https://www.dropbox.com/s/7cs2wsu3ttmyl7....jpg?raw=1]
Stripped:
[Image: https://www.dropbox.com/s/g6idavdzvh64vi....jpg?raw=1]
Toned and a couple lacquer coats:
[Image: https://www.dropbox.com/s/8i9zhcf9mqioan....jpg?raw=1]
Decal on...almost done:
[Image: https://www.dropbox.com/s/2bh5ehrc6pe4nz....jpg?raw=1]
Done and on the shelf (the grill cloth shows a bit too green in this particular light but in reality has a more golden tone to it...its from Kenneth Richmonds offerings):
[Image: https://www.dropbox.com/s/tj386dw99d9l78....jpg?raw=1]
Shiny!
Icon_thumbup
Think that's good or bad?
I think it looks great Bob, keep up the good work.
Gregb
Don't get the big head <wink>, but Paul Sanders does what I consider one of the better refinishing jobs around and yours looks pretty close to his:
http://www.paulsandersclassicradios.com/...ntle-radio
Nice work on a neat little set!
Good OR BAD?
I think my little thumbs up says it all, Icon_lol
I say, the shinier the better!
Ok well, not always, My bald spot is shiny and I don't like that but for radio finishes I like them original or like the day it was put on the store shelf.
A+ job
Kirk
Thanks for the comments guys. I keep learning from each one of these I work on and a lot of that is from this Phorums comments and threads or conversations with Phorum members. Have to get back to the 39-25 that needs attention.
wow I like it Icon_thumbup Icon_clap
There are currently 9642 online users. [Complete List]
» 3 Member(s) | 9639 Guest(s)
