Testing rectifier tubes
Gents, can a rectifier tube, such as a 35Z5 be checked properly using a DVOM?
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
Brian - You can check for continuity in the heater circuit. Because of the tap on a 35Z5 for a pilot light this means there should be a small resistance between pins 2 & 7, also between pins 2 & 3, and between pins 3 & 7. The most important measurement is between pins 2 & 7 - if that is open, the tube is shot.
The meter should indicate an open circuit from pin 8 to all other pins, and from pin 5 to all other pins.
If the heater circuit is continuous, there is a good chance that the tube will work, at least a little.
Thanks Robert. Must be good. Pins 2 & 7 have about 30/35 ohms. Same with pins 3 & 7.
Brian
-Brian
one thing about questionable rectifier tubes, if there is a internal- short in the plates, they can produce a nice mini-light-show for free! Icon_wink
Texasrocker Wrote:one thing about questionable rectifier tubes, if there is a internal- short in the plates, they can produce a nice mini-light-show for free! Icon_wink
Yes, I recall such a lightshow inside a 6X5 some years back.
Best regards. Mike
"Did you say 'utes'?"
I’ve consulted a couple of the books which I got from Jim Koehler, Elements of Radio Servicing (Marcus and Levy, 1947) a...jrblasde — 10:58 PM
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
I think where the shaft comes out of the brass piece, there should be a clip.morzh — 06:47 PM
Well, you're right but the AVC gets to the control grid through the IF secondary, no direct connection to the control gr...RodB — 06:36 PM
Where do I look? 7B7 Suppressor? Both these radios seem to connect the SG to AVC. Which I am not sure why, but then ...morzh — 06:27 PM
