Magnavox saved from the dump.
Threads: 367
City: Dover, OH
Threads: 562
It probably is a decent player.
Not something I collect but definitely worth saving.
Threads: 367
City: Dover, OH
Well, it does sound pretty good. Only issue is it has almost all the original tubes in it and I think a few are getting weak. With six speakers (the woofers point out the sides) and four 6V6 tubes on the amp, it should perform well once gone through.
It looks like a cross between Colonial/Early American and Mid Century.
No multiplex adapter would date it no newer than 1961, as it was in April of that year that the FCC approved the GE-Zenith FM Stereo system as the standard. (Other companies who made competing FM Stereo systems included Crosley (!), Halstead, and EMI.)
I see the tuner does not have provisions to tune AM and FM separately. Before the FCC adopted the GE-Zenith system, some combination AM and FM stations broadcast the left channel over AM, and the right channel over FM (or vice versa); if you had two separate tuners, or a tuner or receiver which could tune AM and FM independently, you could receive these early stereo broadcasts.
Congratulations...and the price can't be beat!
You can roll your own FM multiplex adapter using an IC, a perfboard, and some resistors and capacitors. Instructions are easy to find on the web, just Google "FM multiplex adapter" and it will return several hits.
Threads: 367
City: Dover, OH
Thanks! I will have to look that up. Now I know why my Arvin table radio has a button that brings both bands in at the same time and claims to be stereo. It has the separately tuned AM and FM bands as does the Emerson TV-Stereo console I have.
Threads: 54
That's odd, the function switch has a position that says FM MPX, if that is not FM multiplex what does that mean?
(This post was last modified: 06-18-2014, 10:41 PM by Arran.)
Threads: 367
City: Dover, OH
That's because the system is already designed to have the multiplex added at a later date. This is even mentioned in the instruction manual that the multiplex would soon be available for purchase to install.
Threads: 54
What the model number of the Magnavox?
Threads: 367
City: Dover, OH
I wish I knew. Guess which part of the tag is missing off the back?
Philco 91 Tuning Condenser
Hello,
Does anyone know how the dial plate comes off the tuning condenser shaft? The dial itself id so warped I can't...dconant — 06:01 PM |
Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit...morzh — 04:29 PM |
Transistors are easy.
Or touch your fin...morzh — 04:25 PM |
Hi Mike, I believe I tried different ways to change the header for my post but no luck. Anyway thanks for changing it fo...462ron — 04:02 PM |
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM |
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM |
Welcome to the Phorum, R3Sons! I have very limited experience with car radios other than installing custom radios back ...GarySP — 01:08 PM |
OK, I need to rename this thread to say..Eico 368 TV/FM Sweep Generator instead of the current title..Heathkit Sweep Gen...462ron — 12:49 PM |
There are currently 8739 online users. [Complete List] » 2 Member(s) | 8737 Guest(s)
