Philco 3650
I had an opportunity to pick-up a Philco 3650 the other day.
Is there any difference between it and the 650 except for being built in Canada?
thanks
RoyG
Same thing just made in Canada! EH
Gregb
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3497 online users. [Complete List]
» 3 Member(s) | 3494 Guest(s)
