Recently acquired 116X pic
The cabinet is in about 80% shape. Not bad. If I can touch it up, I'll leave it alone. The set is complete. All acoustic clarifiers are there, and not torn. Main speaker is also clean. The set works as someone in the distant past replaced the lytics. But it doesn't work well. Not that I care, as it will get a nice recap and over-all health check.
[Image: http://antiqueradios.com/gallery/d/79376-1/116X.jpg]
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
Brian,
Wow! That looks like a nice one. Vey clean and well preserved. It should be a great performer too, when fully recapped.
Ed
Sweet!!! Icon_biggrin Icon_biggrin Icon_biggrin
You will have to let us know how the recap and alignment goes.
I'll probably dig in later in the year. Probably well into fall. I have a few others, including the 116B chassis I need to finish. But I'll post the results or problems I encounter.
-Brian
Great shape! Killer find. Icon_biggrin
One of the great ones for 1936.
It will sound fantastic once restored to proper "health."
Chuck
There are currently 9985 online users. [Complete List]
» 3 Member(s) | 9982 Guest(s)
