1931 Philco 111 lowboy - cant locate parts list
Hello forum-
I just picked up a 1931 Philco 111 lowboy and searched nostalgia air for the schematic (also checked for 111-A). The schematics are there, but no parts list. As nostalgia air uses Rider's references, I assume that the parts list is also missing from Rider's, but that's only an assumption since I don't have the Rider's books. Any of you guys know of any other resource I could check? Thanks-
Mark
Tried Chuck Schwark ?
Use 111 parts list. The Rider lists them under the same sch, and the 111 has the BOM.
In case you don't have this yet, I've posted the 111/111A parts list here:
https://picasaweb.google.com/lh/photo/gk...directlink
Thanks Winky Dink - I owe you one!
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
