The R89 and such replicas cabinets
http://www.ebay.com/itm/Philco-Ford-Corp...43cc0b4d1f
Like this one.
Now that everybody finished saying "ughs" and stopped gagging... Icon_lol
A purely curiosity-induced question: what part of it was wood, what was plastic, did they use veneer or it was plastic or photo?
How was it made?
I can clearly discern wool in the base.
The grill cloth might be wool, but probably plastic (too).
They are partical board with repwood style walnut exterior. Like wood paneling.
I always thought they were made from radioactive turnips.
They actually could be.
From digested radioactive turnips, that is. Why waste a perfectly good radioactive turnip.
There are currently 5601 online users. [Complete List]
» 1 Member(s) | 5600 Guest(s)
