Threads: 64
City: Northbrook, IL
According to the code 121 schematic, there is a 10 mfd cap. (#75) between the driver's secondary center tapping and the ground. And there is one on mine,under the chassis, recent replacement. Later 16b sets had such capacitors installed on the chassis (small aluminum can), but in my case there is no provision for it . I checked some photos of the 121 code sets and could not find such capacitor on the top of the chassis.
Also, any place I can find the new large rubber ring for the dial wheel? I can make one, but if the professionally made ones available, I would rather go that way. Thanks.
http://www.nostalgiaair.org/PagesByModel...013139.pdf
(This post was last modified: 07-17-2014, 08:44 AM by fields 100.)
5-band Model 16 sets with the separate electrolytic (75) are early production. Later production models included (75) with one of the main electrolytics, making it a 2-section unit. I'm not near my service info at present, so I do not remember which one but I suspect it was probably (88 ).
If a 16 chassis has the separate capacitor (75), it was mounted under the chassis, not on top.
As for the rubber rings, look here:
http://www.philcoradio.com/tech/drive.htm
Threads: 64
Ron,
I just looked deeper behind all those new caps and wires and one original E-cap IS, indeed, dual.
Thanks so much.
Remember, the positive end of (75) goes to ground. Negative to B-. 10 uF, 50 volts is more than sufficient as a replacement for (75).
Threads: 92
City: Clayton, NC
I made that mistake once.....
Threads: 64
Live and learn... It is so easy to screw up-unless paying good attention to the schematic. Especially with a dual e-cap.
(This post was last modified: 07-18-2014, 01:36 PM by fields 100.)
Threads: 566
Well...fixing radios is about reading schematics. Why would anyone not pay good attention to it?
Threads: 64
That is when one feels so good about his find, that he gets overexcited.
(This post was last modified: 07-18-2014, 01:52 PM by fields 100.)
Threads: 48
City: Tioga, Texas, USA
Fields 100;
Congratulations on selecting an excellent Philco to restore! This is a very good performing set when working correctly. It is well worth the effort to restore.
We will be glad to help along the way.
Joe
KC5LY
Gary
I in fact did, on a 38-14, I think, where I had a speaker with the dead coil.
Well...it kinda worked. Kinda, be...morzh — 10:38 PM |
Mike, what ever happened to that plan you had to try using a rare earth magnet to magnetize the pole? This looks like a...GarySP — 10:25 PM |
RCA T62 is playing.....
Beautiful set.morzh — 09:07 PM |
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM |
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
