Philco 635B?
Did Philco make a 635B(Tombstone)? If so, can anyone tell me how it differs from the 630B.
Thanks.
Derek
Hi Derek
Yes, there is a 635B; it was a mid-season (January 1936) replacement for the Model 630.
The 630B and 635B cabinets are identical; there are some slight electrical differences, and the 635B has a moving shadow-mask behind the dial scale, with openings that allow the dial lamp to illuminate the selected band.
Hi Ron,
Thanks for clearing that up for me. I was having trouble finding info about the 635B.
There are currently 8950 online users. [Complete List]
» 1 Member(s) | 8949 Guest(s)
