Cap block 6287-DU used in 116B chassis question
The schematic list this as a .3/mfd block. I know it's really two .15/mfd. Now, it also list a 200/ohm wire resistor as part of the block. I didn't see anything inside it. This block had over-heated at one point, and all the tar was melted out. I'm also a little confused to which block lugs are used for the caps, vs the resistor. Can someone clear this up for me. Here's the parts listing.
http://www.philcorepairbench.com/bblokcap.htm
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
My 650B used the same part. The bakelite block in mine looked identical to the universal type 6287-ODU. It uses two .15uf caps, one between terminals 1 and 2 and the other between terminals 1 and 3. IIRC, there was even a jumper on the outside between terminals 2 and 3.
Ed
For clarity sake, I'll number the lugs 1 2 & 3 from left to right, starting at the hold down bolt end. So, on mine there is also a jumper between 2 & 3. Just wondering if a resistor internally figures into any of this. I seem to remember talk of a resistor in one thread some time back.
-Brian
There was no resistor in mine. And yes, you have the numbering correct. The jumper is correct between terminals 2 and 3 on the outside. Icon_smile
Ed
Brian
I think you are confusing part 6287-D with 6287-DU in the listings on Chuck's site.
The two are different parts. 6287-D is not used in the 116B as it an older type, not the "universal" type with six lugs which was adopted at the beginning of the 1936 model year.
6287-DU, listed as 6287-ODU on Chuck's site (same specs, just different wax used to seal it), does indeed contain two 0.15 uF caps, connected externally in parallel to make 0.3 uF.
(Edit: Also, the 6287-DU/ODU does not contain a resistor.)
Ed has given you the correct info, also. Icon_smile
Yes, thank you gents. That's what I did. The listing confused me.
-Brian
Silly me, you are right! I read and wrote nF, but was thinking pF.jrblasde — 10:48 PM
0.01uF and 10nF are the same capacitances :lol: Its the rating. Yours are rated to 500V and the Y2 are up to 300V. Obvi...morzh — 10:41 PM
You’re right, yours are much smaller. I must admit that I ordered these without much regard to size. I ordered them back...jrblasde — 10:29 PM
What should I offer?
Thanks, that makes sense. I searched Hepplewhite on Google, and saw some fancy dining chairs.jrblasde — 10:23 PM
My memory had not failed me when I was writing about those inductances. I found them, both 5.6mH and 10mH, both small ax...morzh — 10:21 PM
Joseph, Yes you could do that too. But why did you choose to buy these conspicuously large capacitors? 10nF Y2 caps sho...morzh — 10:02 PM
Thomas Sheraton gave his name to the style. That is others in 19 century took his name and assigned it to the style. G...morzh — 09:59 PM
Excellent point! Thank you, sir.jrblasde — 09:58 PM
Hello Joseph, That looks great only thing I would make sure is that screw has good clean area where it contacts the gr...radiorich — 09:50 PM
Here we are. Boomer Sooner!  :lol: jrblasde — 09:40 PM
There are currently 2167 online users. [Complete List]
» 2 Member(s) | 2165 Guest(s)
