1929 Philco Model 86 Restore on Youtube
Threads: 60
City: Portland, Oregon
I have started a restore of a 1929 Philco 86 on youtube.
Please watch as I attempt to power it up and follow along as I restore the chassis and cabinet in later episodes.
My youtube channel is Buzz1151
Hope you watch..
thanks,
Buzz
Threads: 569
Ron
Having to find things on our own helps fight Altsheimer's. For many of us, old farts, it is a useful brain exercise. Now that troublehooting (I am leaving that typo uncorrected, like it) has become familiar routine and no longer poses enough challenge.
Acked, but there are so many people out there who do not want to search on their own (and I do not necessarily count myself among that number).
I therefore try to be a good host.
Threads: 60
Thanks Ron for those links.
I'm not one for tooting my own horn.
I continue on in Part 3 removing the large condenser can.
I like to use humor in my videos, as this country needs all it can get nowadays.
https://www.youtube.com/watch?v=Anen9-58W74
Threads: 268
Hi Buzz
Saw your videos and had a couple of comments. Your set has no electrolytic condensers in it power supply or elsewhere. All of the condensers are paper or mica.The filters in the P/S are paper and as paper condenser are they are non polarized. Do not replace them with electrolytics as they can't take the high ripple current and will short after awhile (like a month or 2 with daily usage. Ask my model 87.
You mention that the label is riveted to one of the IF cans. Cant happen. Your set is a TRF set not a superhetrodyne. Superhets have IF's TRF's don't. The TRF sets use a number of RF amp stages, a detector, and then a power audio amp. No frequency conversion like a superhet.
On removing the filter condensers in the metal can you could have saved your self a lot of time and construction of the terminal board that mounts on the bottom. By placing the filter can once removed from the chassis in the oven in a pan under it. Heat it to 175-200 degrees for about 30-45 mins. This is enough to soften the tar. Gently lift the terminal board just enough and cut off the wires that hold it on. Carefully pry and use a cork screw or an Ihook to remove the remaining parts in the can. Replace the original caps with 630V paper (mylar) units.
Pls not miss understand my post. Just wanted to clear up a few bits of info in your videos. I'm not trying to degrade or discredit your restoration. Just want the newbies to get the proper info.
GL with your project. Looks like a fun one!
(This post was last modified: 08-10-2014, 02:33 PM by Radioroslyn.)
Threads: 60
Hi Terry.
I know its a TRF radio. I just misspoke IF instead of RF
The boiling was done for comic effect .( hoped you enjoyed that bit)
As for the caps, you are right...another viewer commented on it. I will address that in part 4.
I like to throw in a bit of humor and silliness into these videos.
Thanks for watching...
Buzz
Threads: 60
1929 Philco Model 86 Restore Part 4
now uploaded
https://www.youtube.com/watch?v=sj8Ky7I-54s
I fabricate the bottom plate of the condenser can
and have a good old time.
Threads: 60
1929 Philco Model 86 Restore Part 5
now uploaded, if anybody is interested.
https://www.youtube.com/edit?o=U&video_id=UhYBQrlha18
Yes, please keep those videos coming!
Threads: 337
City: lawrenceville nj
love his video's he actually shows him doing it not just telling along with jokes and comedy
worth watching
sam
Threads: 55
City: Lexington, KY
Threads: 11
City: Dallas, TX
nice series Buzz!
Thank you for being a gracious Host, Ron.. I do a lot of searching... most of the answers I'm looking for are in the archives but I try and strike a balance between lurking and participating. sometimes that means asking a question you know you'll find the answer to eventually.
Threads: 60
1929 Philco Model 86 Restore Part 6
https://www.youtube.com/watch?v=KgkyhxnFiuc
Threads: 54
I can't comment on the potential ESR and ripple issues with using electrolytic caps in these sets, but one thing they will not have is the longevity of poly film capacitors no matter how good the electrolytics are. Most of the filtering is handled by the choke and speaker field coils in these sets which removes the AC ripple current very well. The reason why later sets went to electrolytic capacitors was due to cost, they could produce capacitors with a high value that were compact and inexpensive, especially in relation to filter chokes, that brought the same results and allowed the manufacturers to make the sets cheaper and sell them cheaper.
91H Code 126 Restore
I'm pretty sure that the dotted line I circled in an earlier post signifies that it is applicable to the 226 model which...RealRider — 08:05 AM |
Philco 49-1040
Hello bob,
that underside looks like it is all original !
Sincerely Richardradiorich — 02:07 AM |
Philco 49-1040
Oh yes, many bumblebees and loktal tubes.
The cutout is for the speaker. Here's a photo from a different set.
Bob Andersen — 12:59 AM |
Philco 49-1040
Bob;
Looks like another "Bumble Bee" special, like my Brand Z T.O radios. Is that section they took out of ...Arran — 12:19 AM |
Philco 49-1040
Hello Bob,
You are like the home for lost tv's like how people bring pets home !
Sincerely Richardradiorich — 12:00 AM |
Philco 49-1040
I thought I had an arrangement to restore this set for a customer but his wife said heck no. Instead, he gave it to me....Bob Andersen — 10:29 PM |
I kept working on reassembly this week. I wasn’t able to solder for a few days while it was too cold (single digit low t...jrblasde — 09:27 PM |
Well, powering it up would be too good to be true, and I had that feeling.
Before I did, I decided to check the coils...morzh — 06:02 PM |
Thanks Chas,
sure will give it a look!morzh — 03:39 PM |
Mike,
Lookup murrayatuptown on ARF. Seems he has a dilemma with surplus field coils. Could get lucky and have what y...Chas — 01:26 PM |
There are currently 3100 online users. [Complete List] » 1 Member(s) | 3099 Guest(s)
