Philco 20 Restoration Chronicles
Believe it or not, I was a union painter prior to being an electronics tech for 37 years (and going).
The application of the correct color is, to me, the most difficult and important thing about restoring a cabinet. The commercially available toners, dyes and stains are good, but it is necessary to get one of the tinting kits too. After all where are you going to get Mohawk toner in dark blue? Don't ask where it is used on the OUTSIDE of a cabinet, but it is. Or for that matter mixing the PURPLE lacquer to refinish AK metal parts - yah it kind of looks brown - kind of. OH and get a good airbrush.
Finally got the veneering done on the face.
you're supposed to be in bed, what are you doing veneering radios?
Today I matched the veneer, colored the inside grill wood, and started gluing the major separation obf the back arch.
This one I can't wait to see.
There is a spcecial place in my heart for 20s.
Don't know why....maybe because a 20 was the first radio I restored.
Now that scares me, Icon_lol
Besides the grill work and the molding, this is the one that will be most original. I have matched most of the issues and fixed the veneer but some old repairs could not be fixed perfectly due to major gluing. Of course this is the one that is most special to you..... I will try my best Mike and if it is not up to standards I will buy an airbrush kit and redo the entire cabinet. UMMM After I learn to airbrush. Icon_mrgreen
At least they will be done for K'town (unless I get the surgery) so you better have room in that truck. I need all the space in my car for new stuff Icon_thumbup
Kirk
Oh, I have room. I usually not buying big stuff there.
Taped, toned, cleared!
Now to wait 2 weeks to buff everything out.
Kirk,
I think you can replicate your arch face with succesive applications of a lacquer toner. As you add a coat, it will get slightly darker and you stop when you get the shade you want.
Yes Art, but this is Mikes and I don't want to test my skills on his radio.
Do I scare ya? Good! Icon_twistedIcon_mrgreen
Done!
I dont have the escutcheon do I?
Ah...the 20...whatever they say, but somehow this is my favourite out of all cathedrals.
There are currently 9959 online users. [Complete List]
» 3 Member(s) | 9956 Guest(s)
