  • 1 Vote(s) - 5 Average
Philco 80 Jr. Restoration Chronicles
Is it my impression only or you work faster after falling off the roof? (no I am not suggesting you do that again, the effect might not necessarily be cumulative).
Attempted to match the color by hand and not taped off the grill for toner
The middle section looks right, honey colored.
Today I got to toning the cabinet arch and face.
Then clear and the 2 week wait.
Wow dude! Ausgezeichnet...I mean, ништяк..I mean, you rule!
That looks much better than many of the 80's I've seen refinished.
Very Nice!!!!!!!!!
That is outstanding!
Thanks guys. I need to rub them out but not until September right before K-town. Gotta cure more.
Go back to sleep. I have my parent's lawn sprinkler pump that is under my window.
What excuse do you have to be up this time of the night? Icon_smile
I'm up at 5:50 like clockwork every day. I take naps when pain killers run out of juice though. Icon_thumbdown
Finished and ready to go home. Sorry for pics. its dark out and my garage lights stink
What color toners did you end up using for this?  I am doing a 81B and will need something similar.
Thanks, Bill
This is where I went with my JR.
[Image: http://i1365.photobucket.com/albums/r745...04d941.jpg]
IIRC the center was dark walnut and the outside was extra dark walnut. For the sides I went a coat less of extra dark so it is in between the two. May not be correct, but I like the way it looks. Icon_smile
And yes, I need to dust.  Icon_redface
John
Las Vegas, NV USA
(08-17-2014, 11:14 AM)OldRestorer Wrote:  I'm up at 5:50 like clockwork every day. I take naps when pain killers run out of juice though. Icon_thumbdown
Demerol, ask for it by name. Icon_smile
John
Las Vegas, NV USA
There are currently 6516 online users. [Complete List]
» 2 Member(s) | 6514 Guest(s)
